Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Solução escolhida
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
por Compartilhar
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
por Compartilhar
Adicionar a sua resposta
s_joseph_ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 6,142
