What is the Biomed calibration password for the Baxter Sigma Spectru?
What is the calibration password for Biomed on the Baxter Sigma Spectrum?
Esta é uma boa pergunta?
At the end of infusion use code 1111.
For programming its 429.
Biomed code is 5555.
Please becareful not to delete the drug library.
Found on MedWrench.com so I don’t know if they work.
Esta resposta foi útil?
Calibration code is 8961
Thank you.
Why is calibration not available in Biomed mode, only viewing of stored values?
The 8961 only seems to do the same thing as 5555. How do you get this to calibrate?
It could be 4444 after the drug library has been installed for Biomed.
The default code is 5555 for Biomed after vendor repair.
8961 for the V6.05.13 software on the Spectrum.
Use 5555. You don’t want to perform a calibration, and you shouldn’t have to. In fact you shouldn’t spend more than an hour on one of these if you’re more than a BMET 2. Send these out to Select Biomedical, or a similar company - they often do the repairs at a lower cost than you can find the parts, and they warranty the repairs. When I go into a hospital I count my inventory, then run it by my usual support companies to have them bid on the service. This gets me competitive pricing on repairs that make it simply not economical to do it yourself.
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 84
Duração total: 4,098
