Ir para o conteúdo principal
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Green display on turn off, clearing after 10-15mins
I have had my thunderbolt display for a while and no issues until one day it seems to click, and the green appeared.
After about 10-15mins it disappears and the screen is back to normal.
The green is all over with what looks like some image persistence at the sides.
I have stripped the display back but could see anything obvious then wasn’t sure what to look for. I gave everything a clean with a blower, a long shot but no joy…
Any advice welcome.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Try cleaning the connections with a qtip and alcohol and a soft brush, there might be corrosion just from the humidity in the air.
Update (05/21/2020)
If you open it up it should have a connection where you can change the screen.it should be internal. I use Rubbing alcohol as high of a percent of alcohol.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Allan, thanks for coming back. Which connections? And what alcohol is best?
por
Done and unfortunately no change...
por
Adicionar a sua resposta
James será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 62
