Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
iMac Intel 21.522% EMC 2428
Hello! I have an iMac 21.5 "2011 basic model (2.5 GHz Core i5, 4 ​​Gb Ram, 500 GB HDD ...) is 100% compatible with HDD + SDD + DVD?. I want to install an SDD, it is possible that imac model?. with these accessories (http://www.yourmacstore.com/products.php...) and the SDD would be enough to install it?
The installation could be as follows:
Sata 0 -> HDD
Sata 1 -> SDD
Sata 2 -> DVD
Is it correct?
Is there any tutorial for this model of 21.5 "to install SDD + HDD + DVD?
PD: forgive my poor English (I am Spanish). Thank you very much!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Here is a link to previous discussion on this subject. Hope it answers your question.
Multiple drive connections
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Here's the pictorial guide for installing it: http://blog.chargedpc.com/2011/05/2011-i...
Pontuação 4
1 comentário:
+ A picture speaks a thousand words.
por
SSD's are not compatible with iMac 21.5in.
Pontuação 1
3 comentários:
Would you mind backing up that statement?
por
Sure. There's is no room and you can't put a 4th screw in to hold it down. And it's right under the ODD. So the SSD would be rattling.
por
Maybe you should inform OWC that what they're selling for the 2011 21" iMac won't work according to you: http://eshop.macsales.com/shop/turnkey/i...
por
Adicionar a sua resposta
Alex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,205
