Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
How to replace my Rear panel?
Hi everybody,
So I have some probleme with button on my iphone (random vibrate due to silence button damaged and power button not working anymore)
I friend just gave me the rear panel from his old iPhone.
I just have a question, at what must I pay attention to prevent any damage to my iPhone?
I readed the guide too
Does someone damaged his iPhone by doing this?
Thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
if you are careful and considerate then it shouldn't be a problem. If something doesn't fit, don't force it, make sure you can see what it is you are pushing/pulling/installing. Look at the way your motherboard is shaped and where camera/sim tray/headphone jack/dock are.. this will guide you in putting the motherboard in safely. The motherboard needs to be inserted sim tray end first and sits under a little lip near the power button, if it isn't in right there then your sim tray won't go in, and your LCD won't close..just a hint. ***Make sure before you do anything that you work on the phone when it is turned off (or run out of charge)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks, I will take care of all you said to me !
por
Adicionar a sua resposta
Saxch será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 231
