How do I set camshaft timing
I have an 09 Kia Rio I bought a used head for. They loosened up both cams and the tensioner . Do you have a diagram so I can reset the cams
Esta é uma boa pergunta?
Timing in the Camshaft. Rotate the crankshaft clockwise to 90 degrees after TDC. This will make sure all the pistons are half way down the bore. Now position the dial gauge so that it can read the lift of the inlet valve of number 1 cylinder from the top of the valve retainer. For more in for regarding auto parts you can visit motortiger.com
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 4,103
1 comentário
I need to know what engine it has and is it a single or double cam?
por Allan Barr
