Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Perguntas Visualizar todos
Display compatibility between iMac
I just got an iMac 21.5" A1418 - Late 2013 (EMC 2638) with a broken screen/LCD and i have laying around a iMac 21.5" A1418 - Late 2012 (EMC 2544) with a good screen and a bad motherboard. And I was planning to use the screen, would anyone know if the displays are compatible?
tl:dr is the EMC 2544 display, compatible on a EMC 2638?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
TheBookYard lists them as compatible to each other! 21.5” iMac LCD Panel & Front Glass Assembly (12/13), Apple P/N’s 661-7109, 661-7513, LG panel ID #’s LM215WF3 (SD)(D1), LM215WF3 (SD)(D3)
Esta resposta foi útil?
Pontuação 2
2 comentários:
i'll give it a try and let you know, thanks!
por
Installed display and everything boots ok, image and everything Thanks!
por
Adicionar a sua resposta
Robert G será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 905
