Ir para o conteúdo principal
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
replace broken power connector
i accidentally broke the male end of the power button connector that mounts to the logic board. does anyone know where to source the plastic, the wires are fine, it’s just the tab that goes into the connector? i need the part number.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Please post a photo so we are all on the same page.
por
Adicionar um comentário
1 resposta
It sounds like you’re talking about the button that goes from the power button to the logic board? The best thing I could come up with was an entire power button replacement which would come with that male connector it seems.
You can find that here.
If you’re talking about the power supply there’s a great iFixit tutorial for that here.
Sadly, I’m not sure you’re able to just buy the connector for either but if it is the actual on / off button I’m sure the entire assembly isn’t too expensive.
Imagem de Replace a broken or damaged power supply compatible with an iMac 27" Intel (Late 2009 to Mid 2011).
Produto
iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply
$149.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
purplelv será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 88
