Ir para o conteúdo principal
My Dell G3 is stuck and can't even be shutdown. What do I do?
I bought this laptop around maybe 7 months ago from UAE. I was playing some apex legends and then the screen froze so I thought maybe windows crashed. But then I couldn't shut it down forcefully using the power button and it's stuck in this screen. I have no idea what just happened. Could someone give some advice on what to do.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi,
Have you tried pressing Ctrl + Alt + Del (all three together) and check if you can shut down this way?
Old fashioned but still works.
por
Adicionar um comentário
2 respostas
Solução escolhida
You could unplug the the input power then remove the battery wait awhile then replace both sources of supply.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Service Manual:
https://www.dell.com/support/manuals/nz/...
Take of base cover and disconnect the battery.
Press power button for about 15 seconds and then reconnect the battery.
Look in manual for the memory modules. Release and then reseat the modules.
Replace base cover.
Does it boot up? Is everything O.K. now?
Pontuação 2
Adicionar a sua resposta
Nihal Noushad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,231
