Ir para o conteúdo principal
Modelo A1059 ou A1099 / disco rígido de 20, 40 ou 60 GB / click wheel sensível ao toque
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
7 respostas
Pergunta mais útil
Sounds like replacing the battery would solve the problem.
Esta resposta foi útil?
Pontuação 3
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Pontuação 0
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
Pontuação 0
1 comentário:
please start a new post- just ask a question :)
por Compartilhar
Have you tried a soft reset first to get back to the startup screen?
Pontuação 0
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Pontuação 0
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Pontuação 0
tell me what i cant do
Pontuação 0
Adicionar a sua resposta
cindy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 3,667
