Ir para o conteúdo principal
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Perguntas Visualizar todos
i7 7700K CPU 4.2 GHz
I know that the i7 7700K CPU is now obsolete, but I’ve found one and ordered it! It costs $642 which I think is expensive, especially as it’s gone out of production, but it’s the only i7 that my iMac can be upgraded with, so here goes…
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Thats way to high! You can find them for less! Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz LGA and I know that’s still also on the high side.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Just picked one up for $300
por
@aprstudios - Make sure you align the chip correctly and when you tighten the heat sink down treat it like how you tighten the lug nuts of your cars tires! Are you tightening your lug-nuts in the proper way? Of course we don't need an impact wench! But we do need to be careful we don't over tighten the screws. As an example AMD ships a special tool with there Threadripper chip as its a big issue Ryzen Threadripper tool
You'll also need to use care applying the new thermal paste. As you only need a little! You want just enough to cover the die cover, you don't want it leaking over the sides.
por
Yes, I’ve built up a nice overview of videos and texts regarding the CPU upgrade. Thanks again for your help, it’s seriously appreciated!
por
Adicionar a sua resposta
Adrian Swift será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 242
