Ir para o conteúdo principal
The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
20 Perguntas Visualizar todos
iPad mini 5 screen adhesive tape
I haven’t been able to find somewhere to buy adhesive tape or good adhesive to repair my iPad mini 5 and was wondering if anyone on here would know where I could get some.
I am located in the UK just FYI
Many thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
A lot of us repair shops will use this if we can’t get precut as the precut adhesive is made from this: Tesa 61395 Tape
I recommend you use a Q-tip and some acetone to clean any remaining adhesive off of the frame, then once the display is glued to the frame, heat it up like you’re taking off the display and clamp it down around the edges or use something to apply light but firm pressure to the edges. This will ensure your screen is firmly secured.
Imagem de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Produto
Tesa 61395 Tape
$5.99
Esta resposta foi útil?
Pontuação 1
tesa tape 51965 is the preferred tape to use
Pontuação 1
1 comentário:
Wonderful! But where can I buy it in the U.S.? An online search indicates only European sales sources.
por
Adicionar a sua resposta
Robert Beech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 422
