Ir para o conteúdo principal
The Motorola Moto Z4 is from Motorola's Moto collection and has model numbers XT1980-3 and XT1980-4. It is also 5G capable.
20 Perguntas Visualizar todos
Motorola Moto Z4 Charging Port Replacement
How do I remove the charging port from the board to replace it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
I tried as I have replaced a number of other soldered ports. This seems permanently adhered with some kind of enamel. Not to mention two rows of contacts, one in front and on top of the other. No idea how to get it off safely.
Esta resposta foi útil?
Pontuação 0
Get a MotoMod battery pack with it's own change port. Morphie makes one. There are some with wireless charging built in.
Pontuação 0
1 comentário:
You'd think that's a simple fix / workaround (I certainly did),... Unless the problem with the Z's port is that it thinks it's powering an external peripheral, in which case the phone seems to not draw power from the Modpack.
por
Adicionar a sua resposta
Kim Alband será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 1,057
