Stuck In dfu mode wont restore with itunes Either
So I have an IPad 5 With an IPad 4 logic board It got repaired by a technician not from apple cause we were out of warranty. It all began when I factory reset the Ipad after it completed the reset it still booted up fine then I updated Via itunes it and it would not accept the Update it also wont restore and I always get the Error 3014 Ive tried doing it manually with different ispw and Still wont work I also Tried other cables Hope someone can help me really looking for some thing to do in quarantine
Esta é uma boa pergunta?
Pontuação 0
12 comentários:
Did this work after the logic board swap?
por Compartilhar
Can you kick it out of DFU mode by holding Home and Power until the Apple logo shows? Also, can you explain more about the “iPad 4 logic board”, because it shouldn’t be possible to swap it into an iPad 5.
por Compartilhar
I worked after the logic board swap fine
Ive also tried kicking it out of DFU mode but It wont work
por Compartilhar
@mronion64 I Checked the serial number of the Ipad and searched It on apples data base and found it was an Ipad 4
por Compartilhar
@mronion64 I dont really know what happend because my dad was the one who got it repaired
por Compartilhar
Exibir mais 7 comentários
Adicionar um comentário
