Ir para o conteúdo principal
Food processor from Vorwerk manufactured and first distributed in 2014/2015 (Europe/US).
Thermomix TM 5 Error C142
Hello, my thermomix still shows error C142. After turning on and attempting to turn on the speed, you can hear the engine trying to move its arms and error C142 appears.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I need to change the cable that bring the electricity to my Thermomix. Can you do this for me?
por
Adicionar um comentário
1 resposta
Solução escolhida
Thermomix has been repaired. The gear in the arm control motor was damaged
Esta resposta foi útil?
Pontuação 1
8 comentários:
Hi. Did you repair it by yourself? I know how to open the TM5, but not how to repair this motor
por
The plastic 9 teeth gear attached to the arm control motor is damaged, I can't find that spare part anywhere.
por
Many thanks!!
por
Hello,
same C142 error
First I thought it was the cover sensor but it was in fact the gear on the locking system motor.
I changed it with a new one in brass and the TM5 is working well again .
probel fixed !
por
Exibir mais 3 comentários
Adicionar a sua resposta
Mariusz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 41
Últimos 30 dias: 158
Ao todo: 13,374
