Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
Replacement fan is not working
Last night I replaced my Switch’s fan with one received from iFixIt. After closing the system and powering it up I thought it sounded a little too quiet. I gave it a few minutes and the fan never seemed to spin up. I took the back cover off, not the plating, so I could see the fan while the Switch was powered on. It wasn’t spinning at all. I took everything apart and put the old, extremely loud fan back in and that fan spun up as it should, albeit quite loudly. I tried re-seating the cable for the replacement fan and that did not help. Did I simply receive a defective fan or is there something else I should check or be concerned about?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi @aaronw630
Since you mentioned you swap the old fan and it works,
Contact Ifixit, most probably the item is DOA
Esta resposta foi útil?
Pontuação 2
1 comentário:
how we can fix the switch for the fan
por
Pontuação 0
Adicionar a sua resposta
Aaron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 1,180
