Ir para o conteúdo principal
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
Esta resposta foi útil?
Pontuação 2
screen unlock system rebooting and taking off the code.
Pontuação 0
1 comentário:
Would you mind putting this into a complete sentence?
por
Repair on my screenlock chromatic code 2generation code.
Pontuação 0
1 comentário:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
por
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
Pontuação 0
Adicionar a sua resposta
fran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 6,163
