Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Perguntas Visualizar todos
My joystick doesn’t work anymore what should I do to fix it?
in a fit of gaming induced rage I decided it would be a good idea to slam the controller against my knee. It feels like it’s not attached and won’t stay in the middle will I need to buy a new controller or can I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Best bet would be to pick up a cheap Torx t8 security screw driver and take the screws off the controller and try and reseat the controller stick. There are two screws in each handle and one hidden behind the label on the battery pack.
There are many tutorials online about how to do it without breaking your controller, which is very hard stuff up, you'll be fine.
My right joystick is slightly moving up
https://gaming.stackexchange.com/questio...
Hope my answer helps you some way.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Thomas scheonbachler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 638
