Pixel 3a not charging after outer shell replacement
I took apart my phone recently to replace the plastic outer backing as it had been damaged. After putting together the phone everything works except for the USB-C charging port. Plugging it into the computer does not work either and the phone does not detect any USB being connected. Another issue is that when I power off the phone with the power button, if it is connected to the charger it will turn on immediately after. Even booting into fastboot mode and selecting power off from the options does not work and it powers on again. Powering it off with charger disconnected keeps it off and it functions as normal then. Have I shorted my motherboard somehow? Or is this a daughterboard/charging port issue?
Esta é uma boa pergunta?
I am having exactly the same problem but without ever taking apart my phone. I suspect some rain may be the reason.
por tolsnel
