Ir para o conteúdo principal
xbox logo problems. help!
when i turn on my xbox 360it sometimes freezes on the logo and doesn't display Microsoft under and since its only till the logo ends without Microsoft displayed can someone please help
Esta é uma boa pergunta?
Pontuação -1
4 comentários
Please be more specific. Does it show any red lights? Does it get too hot when booting? If you have enough skills, try to open it up and check the heatsinks and fans. Oh, do you have at least 5 cm ( about 1 inch) of space behind the console? Is it got repaired (for RROD, for example) before?
por
green lights
por
its cool and it still freezes
por
solomon, as usual you ignore requests for further clarification, you subsequently return to your very vague question, just to leave rude comments. NOBODY NEEDS to give you anything.
por
Adicionar um comentário
1 resposta
Solução escolhida
Get it repaired. That is the only thing that I can imagine right now. Describe to repair shop that it freezes when booting up. It is probably the easiest and cheapest solution.
Esta resposta foi útil?
Pontuação 3
2 comentários:
It has been 8month since this was answered for you. If you are really that concerned about it, you should have rechecked more often. pcmaclinuxgeek tried to solicit more information from you, which as usual, was ignored by you.
por
Its because I forgot about this site.
por
Adicionar a sua resposta
solomon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 552
