How to diagnose high Kernel_task
I have a mid 2014 Macbook pro. It will not turn on if i just press the power button I must hold it for a while until the apple logo is on and then once it it is on it is very slow and the kernel task is at 240% right from the start up at idle.
I have; reset the SMC and the NVRAM, reinstalled a new OS with a different SSD and downloaded TG Pro to see if the fans and the temp sensors are working.
Does anyone have some more suggestions as to diagnose my problem? I want to replace the logic board as a last resort.
Esta é uma boa pergunta?
2 comentários
Let see if you can get the onboard diagnostics to give us an error code. Restart your system and press the D key. Let us know what you discovered.
por DanJ
Hi, thanks i did it and there were no issues found. Reference code: ADP000
por Marco Robles
