Which screws does MSI gs63 use?
I want to replace my MSI laptop screws because they are broken.
Esta é uma boa pergunta?
From what I can find it is M2.5 x 6.5mm, Phillips Head #1 screws.
It sounds like the screws are stripped, so this guide may help you get them unscrewed if you have a hard time doing so.
How to Remove a Stripped Screw
Hope this helped! :D
Esta resposta foi útil?
Thanks you !! I will try it immediately.
No problem and good luck! :D
hello from france is it okay with Msi GS66 ?
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 61
Duração total: 5,436
2 comentários
What screws are you wondering about? The ones for the bottom cover?
por Erik Eriksson
Yes, the first ones that you need to remove. @eke0909
por Jiahao Cheng
