Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
How do I know if it’s an iPhone X or Xs
Hey guys, recently acquired an Iphone from a family member with a swollen battery (don’t want to risk turning it on) and was wondering how can I identify what model it is without turning it on? (not even sure if it can).
Any Ideas?
thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Visually identifiable:
X: Symmetric bottom
Xs: additional antenna slits that cut the bottom left grills short.
Esta resposta foi útil?
Pontuação 2
Hi Daniel,
Pop out the sim tray, the IMEI of the device should be laser etched into it. use https://www.imei.info/ to ascertain which model your family member has.
  • if you do decide the replace the battery yourself, have a bucket of sand at the ready. It’s one of the best things to quel that type of fire.
My honest opinion would be to take it to apple. normally they would take the phone from you, replacing it for the cost of a battery replacement.
Hope this helps!
Pontuação 1
1 comentário:
Thanks! I’ve done plenty swollen battery replacements so far so I’m sure I can handle the challenge. Our local and only apple reseller won’t accept it because it was badly damaged in an attempted mugging. Broke the screen and back panel, and my uncle got then replaced at a very low quality repair service (no TrueTone). So if I want to salvage it I will have to do it myself.
por
Adicionar a sua resposta
Daniel Guerriero será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 471
