Water pump system Ford Escape 2012 25 lt it's coolant close to the wat
It's leaking coolant near the water pump should I change water pump thermostat
Esta é uma boa pergunta?
More likely to be the water pump itself or perhaps a bypass or other hose nearby to the pump that is leaking. You need to visually confirm what is leaking with an inspection mirror and directing a strong light into the hard to see areas around that pump to see exactly where the water is coming from. There are also a lot of low prices boroscopes that hook up to smart phones these days that can help with tight inspection jobs like this.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 105
