My GPU fan is making an annoying noise.
I have an Acer Predator Helios 300 PH315-52-75DE. The GPU fan, on the right side, is making a low pitched rattling noise. It’s very hard to describe, but it’s like a purring or growling. The fan propellor is metal not plastic for some reason, but I think that could be it. I tried using some foam tape for shock absorption, and that did help a bit. My only idea is to buy a replacement fan and swap the propellers. I can include some pictures if that would be helpful.
Esta é uma boa pergunta?
3 comentários
Hi
I have I think the same problem, my IT guy thinks its coming from the speakers however just having it turned on you can hear the buzzing noise, but connect it up to the VR and it gets loud to the point you have to turn if off.
por fran150352
Im having the same issue, GPU fan, right hand side of laptop. Slight rattling noise like its slightly off balance.
por michaelaston28
I'm having the same problem right now as well, it started yesterday and it rattles the laptop and makes an annoying noise, I've been trying to look for a teardown guide but I can't seem to find it at all
por ruli
