Ir para o conteúdo principal
The Casio CTK-3000 has 61 keys (5 octaves), about 400 instruments, and a built-in metronome.
Static in right speaker and low volume in left speaker.
Hi. My father has a Casio CTK-3000 which he has owned for a few years. He turned it on today for th first time in several months and now there is static in the right speaker and low volume on the left speaker. We've tried connecting to an amp and the static is still there. We have even tried plugging it into a different outlet and still the same result. While it was not being used, it was covered.
Does anyone have any ideas what might be causing this. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Internal wires or cut or severed. It is toast. That happened to mine 6 months ago.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Sorry to hear that tho...
por
Try check and replace the op amp after the DAC output. I fixed a Yamaha piano having the similar issue. One of the troubleshooting method is to probe the signal directly from the op amp output pins of both left and right channels to see if it's any abnormality in the sound.
Pontuação 0
Adicionar a sua resposta
Yves será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 591
