Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
iPhone 7 plus homebutton working but fingerpirnt isnt working
Hello Ifixit
I encountered an Iphone 7 plus having an issue on fingerprint sensor the touch id has the same serial with the board itself but when i already boot it up and setting up the fingerprint the fingerprint tab just displays their and not noticing my finger . Double tap to go down is okay and homebutton is working so fine . Can you help me fix the issue ? Thanks i already tried to rearrange the flex cable but still didnt work tried resetting it also etc. nothing works .
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What led to this problem?
por
@imicrosoldering Battery Replacement and backcam replacement .
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Give the display connectors and cables a good inspection. If you creased or tore one of the cables, that could lead to touchID issues. Can you try a new screen?
Esta resposta foi útil?
Pontuação 1
5 comentários:
Yes like @hootonberg said a new screen should fix this issue.
por
I already tried a new screen and it didnt work also .
por
Same with the old one where the homebutton is good(Pressable /Vibrating when being clicked) but the fingerprint capability is not working .
por
You said you reset the phone. I don’t know what method you used but if you haven’t restored through iTunes I would give that a go it sometimes fixes the problem. If that fails it would point to a failure in the home button assembly.
por
@imicrosoldering thank you sir will try to restore it on itunes
por
Adicionar a sua resposta
Fixie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 64
