Ir para o conteúdo principal
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
Why is my rescue 900 jump starter not charging
Green light saying fully charged when My jump starter is plugged in but its dead..will not charge
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
How old is the unit? Sounds like the batteries are at EOL (End of Life), they are normally replaceable.
por
the device cannot switch off
por
it is new just three months only, when use it first time it has this problem
por
Adicionar um comentário
1 resposta
If you don't keep those things fully charged at all times they won't take a charge after a while. Also if you don't fully charge it before first use it can really hurt the internal battery. Hope that helps. I'm in same predicament with mine.
Esta resposta foi útil?
Pontuação 0
1 comentário:
so what do you do with it?
por
Adicionar a sua resposta
Shannon Staggs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 2,765
