How to fix monitor blacking out randomly.
So I have a monitor that goes black every now and again. There is no pattern to it at all. Sometimes it works fine for days other times it goes dark every 10 minutes. It still seems to be back lit as it does not go totally black as if it were switched off. It's more grayish then anything else.
Switching it off and back on again fixes the problem.
Tried using it on different PCs using different connection methods. DVI, DP and HDMI give same results.
There is no power saving/auto switch off option in the menu.
I am waiting for a new PSU to be delivered and will give that a go.
Would appreciate any help.
The monitor is a Crossover 2714 UHD
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
