Ir para o conteúdo principal
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
What is wrong with my phone
My phone has a crack on right side corner in middle of screen. When I press the power button it has a white flash at the lower screen or some times it shows my display at the top half of the screen with the top right corner in black and white at the bottom. Can someone please help. I need to know what's wrong and how to fix this.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Your phone has an OLED panel, and what happens from time to time when you crack the screen, you also damage the OLED panel. You’ll need to get your screen replaced to fix the issue.
Esta resposta foi útil?
Pontuação 1
2 comentários:
The entire screen? The glass top? The LCD digitalizer? Sorry I see so different things when I type screen replacement
por
Yes the entire screen needs to be replaced. The screen is composed of the OLED panel, digitizer, and glass. You cracked the glass and the OLED panel no longer works. And it's very difficult to glass only repairs on OLED panels. If you're going to do this yourself, order a samsung service pack as they're the easiest and it's a genuine samsung part. Never buy parts from Amazon, eBay, Craigslis, Wish, or AliExpress. They're junk...
por
Adicionar a sua resposta
Mookie West será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Ao todo: 342
