Ir para o conteúdo principal
A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
Can I re-solder a lightning cable?
The cable is broken near the connector, can I re-solder it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
It’s not something I would recommend!
If the cable is physically attached to the device can you open the device to get to the points the cable wires are connected too?
If you can I would just replace the full cable.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Hutchoo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 873
