Ir para o conteúdo principal
Big white horizontal bars on screen
hello,
recently i worked on u2 ic on an iphone 6s and and when i tried to turn it on,my power supply stopped at 0.03amps. then i couldn't work on it for few days and today i tried to turn it on again. suddenly it turned on normally and after 2,3 seconds from apple logo,big white horizontal lines (nearly 1 inch) appears and it goes up to down and keep repeating.i have no idea what i’ve done wrong.i’m new to microsoldering and done only 3 u2 replacement so far.(all went smoothly).this phone had a battery draining issue and heating from bottom initially.so i guessed its a faulty u2 without testing voltages and proceed with the u2 replacement.any advice would be highly appreciated.thank you for your time.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would request to change the screen. If that does not work to replace the motherboard with a new one and that it comes with the home button.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nuwan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 23
