Ir para o conteúdo principal
Repair and disassembly information for the fourth-gen iPad Pro 12.9". Announced and released in March of 2020. Model A2229.
Transperent line right at the middle of the screen.
I just bought the new iPad and I’ve noticed (when it’s off, during condition checking) that it has a line right ar the middle of the screen. It doesn’t make any difference in the brightness, colour or sensitivity so it might be something like a “seam”. In any case, I just need somebody to say that it’s “OK” so my wife can relax. :)
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Can you take a picture of it and post it here so we can see Adicionar imagens a uma pergunta já existente
You shouldn't see any lines.
por
@danj that's the best picture I can make. On the photo is visible ever so slightly, right at the middle.
por
I have exactly the same Line on my 21 iPad pro 12”
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you buy it new or used?
Technically there shouldn’t be any seams so I can’t tell you why this one has it. If its used its possible it was repaired and the marking was caused during the repair.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Brand new, from Argos.
por
It becomes very peculiar. When I tried to clean up the screen and rubbed with a cloth (quickly, without applying pressure), the line disappeared but after a while, it came back... So I decided to make a little test, on one side I rubbed the screen the same way with a cloth again and left the other untouched which as a result removed (for a while) the line.
por
Adicionar a sua resposta
Artur Shalimov será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 695
