Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
HDMI PIN 18 issue
Hello everyone,
I bought PS4 with faulty HDMI port to fix it, learn something and get some practise. I am now waiting for my new HDMI port, but I have noticed something on the bord. As I checked conductivity between PADs and points from the diagram, I found, that PIN 18 is not connected to the capacitor on the right side(18).
I have also noticed that the back side of the diode and capacitor(Yellow dots) are connected and both shorted to ground.( Front side of the diode and capacitor Is connected too, but not shorted to ground.) Is that right ? I dont have another board to compare with. And if yes, where does PIN 18 go? Could that be an Encoder IC fault?
Esta é uma boa pergunta?
Pontuação 5
3 comentários
@marcinn ..please list which board you have for further diagnostics help
por
Where can I get that? Theres SAB-001 on motherboard, Is that it?
por
Adicionar um comentário
8 respostas
Pergunta mais útil
martin … for sab-001 follow this pinout.
https://www.youtube.com/watch?v=KTQ5JkaL...
skip to the end for the testing points. if it doesnt match, theres a fault. post back for further assistance.
Esta resposta foi útil?
Pontuação 1
10 comentários:
Yes, the PIN doesnt match the video
por
youll want to remove the component that doesnt match and test out of circuit. if it tests good, place it back and continue. something is shorted. it could very well be the hdmi contoller. i would start there and recheck the pinouts.
por
Okay, I am gonna try that, thank you
por
@jostewcrew so I have desoldered the diode and capacitor and noticed, that I have 3 pins on the HDMI controller (firts 3 from the left side behind the HDMI filters) shorted together. Dont you know where they should connect ? And when I removed the components, the pin Now connect to the right place
por
Sorry, not only First 3, also some that Are connected to HDMI filters are shorted with first 3 pins
por
Exibir mais 5 comentários
Hi, I have the same problem, maybe someone could give us feedback about value of this cap and diode from working MB. For me its 1,5 Ohms from the left side of thie components.
Thank you!
Pontuação 0
14 pin point root i want
Pontuação 0
i need help!!!!!!!!!
Pontuação 0
i need help!!!!!!!! andrew!!!!!!!
Pontuação 0
how to get sab-001 ps4 hdmi disgram motherboard!!!!!!!!
Pontuação 0
Capacitor and the diode are both grounded (caps negative if polarized diodes non-striped side)
Capacitor is noise filter
Diode is a protection for polarity
Both are for local part of circuit
Pontuação 0
Hey friend, do you happen to know which ceramic capacitor is the one next to the zener diode?
Pontuação 0
Adicionar a sua resposta
Martin Jančík será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 158
Ao todo: 13,051
