Why does my Lawn Tractor shut off when hot?
I have a White Outdoor LT-1855 H Lawn Tractor with a 18horse Briggs and Stratton engine. I started having a problem with it shutting down after running for a while. Seems to shut down when it gets hot. It will run fine and I can mow for about 15-20 minutes then it shuts off. If I wait for a while for it to cool it will crank and run for a short time (maybe 3-5 minutes) and shut off again.
I have tried to correct the problem doing the following
Changed out the Spark Plug
Changed the Ingnition Coil
Dumped the gas and put fresh in.
Changed the fuel filter
Loosened the gas cap to make sure it wasnt a faulty cap.
Pulled the Air filter to eliminate a bad clogged air filter.
Charging system seems fine getting 14 volts at the battery when running.
I am not sure where to go at this point. Any help would be greatly appreciated!
MikeQ
Esta é uma boa pergunta?
3 comentários
To make things easier, you'd better go to a service that employs good professionals.
por Rachel Lawrence
To make things easier, you'd better go to a service that employs good professionals. You don't have to have them do the repairs, and there are many youtube guides for such cases. It is enough to consult them. I would recommend https://www.heming-engineering.co.uk/tra... You can also order parts through them, and they will come from there quickly and without delay. They have an extensive database of spare parts and specialists that allow them to work with any machinery. My advice for the future is to buy only original parts and service your equipment on time. That way it will last you a very long time. Any machine likes care, and if you keep an eye on its condition, it will indeed thank you. I hope you'll be able to solve your problem.
por Rachel Lawrence
I have the same issue and have tried.all the above including the gas line. Anywhere else.to go with it?
por Imzeek
