Ir para o conteúdo principal
Came with Seagate Hard Drive, find 2TB replacement?
My Mid 2010 i3 3.2GB 21.5" iMac has a 1TB Seagate ST31000528AS. I have to replace HDD's with the same manufacturer for the thermal sensor, right?
Where can I find a Seagate 2TB HDD that I can swap out with the original?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Yes you are correct this does need same manufacturer. I believe also it must be of the same series, which means you are going to want to find a drive to the tune of ST32######AS. I saw a few for reasonable prices on Newegg. I believe this is what you are looking for.
Esta resposta foi útil?
Pontuação 4
2 comentários:
If you are having problems with your current hard drive it is still under warranty by Seagate.
por
Always have clear and informative answers. +
por
Thank you for the reply, that explains what I need to know.
Nothing wrong with the current HDD, just need more space.
I'll pop over to Newegg and check it out.
Pontuação 0
Adicionar a sua resposta
Dave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,803
