Ir para o conteúdo principal
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
error light paper blinking
Hi,
My epson printer L3110 having light paper blinking but already check all is good. No paper jammed or any object inside the paper slot. I check with system show : MEMORY CARD IS LOADING ERROR
so what should I do to get the printer is normal? And what the solution to solve this error.
This is new printer as i buy last month.
Hope can help and run as normal.
thank you
Rafi Haron
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Pergunta mais útil
Knowing the model number is always helpful.
This can sometimes revive epson printers that are being difficult…
https://epson.com/support/updating-your-...
Esta resposta foi útil?
Pontuação 1
The way to solve this problem is quite easy if you want to follow the procedure I explained like this, open explores -> this PC -> Manage -> device manager -> print -> update driver.
After the driver is updated, if it doesn't work, just uninstall the driver then download it again by clicking via the link below:
download driver epson l3110
Pontuação 1
i know ,that probel will make you job disturb, i want to give suggestion you can find theright driver for your printer driver. I know but it is for model epson l1110 may be next time i will find good driver source for your epson l3110
Pontuação 0
Rafiharon bom dia,
deve ser algum sensor q esta com problema em sua impressora, e por isso acusa o erro de papel, verifique tambem se pode ser a mola do sensor de papel, pode ter escapado.
Pontuação 0
Adicionar a sua resposta
Rafiharon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 4,222
