Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
WIFI not working after replacing lightening connector
I replaced the lightening connector assembly and everything seemed to go back together just fine, but after starting up the phone again, the wifi is not working. Specifically, the wifi cannot be enabled, the switch in settings is off, and cannot be turned on.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
When replacing the lightning connector, did you remove the logic board or just lift it up?
por
If removed could have damaged the wifi antenna signal flex or even ripped the flex to it.
por
@Jade Richards I did completely remove the logic board and then re-installed. I guess my first step would be to re-open and inspect the wifi antenna component and its connections. I'll do that and post any updates!
por
Adicionar um comentário
1 resposta
In my experience, when something is grayed out on iPhones it’s because that component is not functioning. I have also seen a bad rear camera cause the flashlight to not work. It’s likely you accidentally damaged the Wi-Fi antenna.
It’s also possible that the connector is not clicked in correctly. There is also a screw that holds a bracket to the frame. Not sure if this grounds anything but that could also be a potential reason this is not working.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 47
