13" MacBook Pro, 2018 display glitch
It appears that the ribbon in my MacBook Pro screen is loose or damaged. It displays correctly in certain open positions until bumped or moved, then gets extremely distorted with vertical and horizontal lines. Is the ribbon in the hinge a replaceable part or is it part of the whole screen?
Can anyone point me in the right direction, thanks in advance
I will try to find an adapter connect an external monitor. I have done a apple hardware diagnostic and came back without errors.
Esta é uma boa pergunta?
1 comentário
Can you post a few pics so we can see what you are encountering Adicionar imagens a uma pergunta já existente
Are you able to connect an external monitor into your system? If you can, does the external image stay normal when your internal messes up?
por Dan
