Kernel panic and system not booting
Hi everyone
I am having trouble booting my ayatem..i have a mid 2009 macbook pro with a 120gb ssd disc. After years of great work it has started to give this error while trying to boot with no succes
After searching the forum I trend to think that this post may have an explanation for my problem: https://es.ifixit.com/Respuestas/Ver/429...
But, how can i be sure that's my problem and not another? Has anyone experienced the same?
Thanks for your help
Update (03/19/2020)
Update (03/19/2020)
So, the SATA disc was installed several years ago and have been working nickey since then until today.
After the first warning, i disconnected the ssd disc and connected it again and was able to boot the system. As soon I $@$* it down in order to close the back cover and rebooted again, it started with the kernel panic.
I have tried several things since then, such us:
- Remove and reconnect both discs
- Remove and try alternatively both of the ram cards
But so far i only get the kernel error i displayed above.
Esta é uma boa pergunta?
Carlos - OK, let's back up here! You have two drives in this system?
por Dan
Correct. Ssd is for the system and i have a hard drive for storage
por Carlos Albaladejo
Disconnect both drives fully. What happens then?
por Dan
In that case it displays forbidden sign
I think i need to purchase a new ssd asap, since online retailing in my country is not 100% reliable due to coronavirus restrictions. Can i use any kind of sata ssd from I to III regardless the fact that my computer can only read/write at SATA I maximum speed or should I focus on some specific type of ssd?
Exibir mais 11 comentários
