Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Perguntas Visualizar todos
A1466 MacBook Air 2015 does not power on
Have a Macbook Air here that will not power on anymore. The light on the magsafe connecter comes on when it is plugged in and turns orange but nothing happens when the power switch is pressed.
From what i’m told it first just started to not power on then a few weeks later it would suddenly power on when tried then the owner was afraid to switch it off and left it powered on and it went to sleep after which it never powered on again.
I’ve opened it and disconnected the battery and it still does not power on when the magsafe is plugged in .
I’ve a good few years experience repairing PCBs but the only equipment i have at home is a multimeter. Can anyone point me in the direction of test points or a guide to troubleshooting this? I’m fairly competent with electronics repairs so please go into detail if possible.
Thanks in advance anyone! Any help will be greatly appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Any sign of liquid damage in this MBA ? Did you remove the logic board and made a visual inspection of the two sides (magnification would help). It takes only a little corrosion on a critical component to kill the board.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I haven't completely removed the logic board yet as i'd like to know a bit more before i go that far but i'm fairly certain there have been no spillages
por
I saw many MBA boards that were very clean, no sign of liquid damages but one component corroded, Hard to know where it comes from but once repaired the MBA was ok.
por
Adicionar a sua resposta
Cricky Lyttle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 72
