Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Unable to activate iPhone 7
Hi, Ive been given an iphone 7 and, since trying to start a fresh with the phone, im presented with a “unable to activate” error message.
I have tried entering into recovery mode to update or restore, both unsuccessful.
I then went into the Apple store and was told it probably because ive a aftermarket screen fitted and sent on my way?
Any ideas ?
Regards,
Michael
Esta é uma boa pergunta?
Pontuação 1
1 comentário
For some reason, ive switched it on today and its managed to update to 13.3.1, which it wouldnt do before.
Not sure this is of any relevance , but thought id mention anyway.
por
Adicionar um comentário
3 respostas
Solução escolhida
This will have nothing to do with the screen. It is more likely a baseband CPU problem created from an audio IC repair. Was the phone able to connect to a cellular network before you restored it?
Esta resposta foi útil?
Pontuação 3
1 comentário:
I didnt think it would be the screen either and had the feeling i was being fobbed off.
Yes, the phone was working fine until i erased things and updated it.
por
At the HELLO screen when you press the circle with the i, does it show your imei nr# ?
Pontuação 1
3 comentários:
Hi, no it doesnt give me the IMEI number. It gives me one number. I dont have the phone to hand and cant think which number this is?
por
Because there is no imei nr i think that your baseband ic is faulty.
por
Sounds like its above my skills to fix then .
por
My iPhone7 needs email to icloud and password, but the owner has forgotten
Pontuação 0
Adicionar a sua resposta
Michael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 597
