Ir para o conteúdo principal
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 Perguntas Visualizar todos
Why won’t my interior lights turn on when the doors open?
About a week ago my interior lights stopped coming on when I would open the doors. All the lights still work, they won’t turn on automatically when the doors open. I can not figure out the problem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Take a look for a lighting relay or fuse especially if it doesn’t matter which door is not triggering the lights. Most likely the wiring from each door switch comes together at a relay and the relay contacts are what enable the lights to come on. Sorry I don’t have details on the specific model but you might be able to locate one or two fuse/relay boxes (normally one under hood and possibly one below the steering console around the gas or brake pedal area. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brianna Murch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 53
Últimos 30 dias: 659
Duração total: 6,009
