Ir para o conteúdo principal
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
54 Perguntas Visualizar todos
Console power diode blinks for a second, then turns off.
As in the title, when I’m trying to turn the console on (with new, top brand batteries) the power diode blinks for a moment and then goes dead. I am sure it’s not caused by loose wires, dirty battery contacts, broken circuit paths or rust, as I cleaned the device after buying it. No parts look rusty or leaking either.
I’m afraid it could be an issue with resistors, as I heard they tend to burn, but I’m not sure.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
i’m answering my own question, as i found the solution lol
turns out i just had to absolutely spam power switch for few minutes, so the contacts inside could clean a bit. and now it works perfectly fine! turns on every time. probably a little bit of IPA could also help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Roth será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 67
