Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Perguntas Visualizar todos
Screen lifting after repair
I had a screen replace on my iPad Air 2 and I have had to return three times because the screen lifts from the body.i was told they use a liquid glue and it must be something I’m doing.has anyone else had the same issue and is there a fix as it’s getting expensive having to return it to the repair place.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
You shouldn’t be paying for ‘screen lifting’ issue as the onus is primarily on the repair shop, it was either a bent chassis which they neglected to straighten out, or they used a cheap adhesive that usually is the culprit for weak adhesion.
I’d argue for a free warranty repair or at least refund of whatever price you paid for repeated work.
Esta resposta foi útil?
Pontuação 2
My iPad Pro does this as well, because of a bend. Make sure to your iPad isn’t bent.
Pontuação 0
1 comentário:
Going to wait till I get my hands on a set of feeler gauges and check it properly.thanks for the input
por
Adicionar a sua resposta
Caleb Crone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 165
