Ir para o conteúdo principal
Informações de reparo e desmontagem para os fones de ouvido Powerbeats Pro totalmente sem fio. Lançados em maio de 2019. Número do modelo: MV6Y2LL/A, MV702LL/A, A2047.
Is the little screen behind the rubber ear tip replaceable?
The little debris screen that sits behind the rubber ear tip fell off and is gone. I’m sure this is going to cause issues down the road, can this be purchased?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Yes, you can buy in-ear generic meshes. Please measure size. Not sure if it's 3 or 4mm size. I've replaced both metal meshes, as they got loose after couple of years of using the PowerBeats Pro.
The generic meshes you can find will work. Make sure they have adhesive.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi
Sorry there wasn’t a answer sooner ,iv only found it unintentionally but here’s your answer
Iv never seen any sold but with some precision adhesive skills and a donor earbud it can be replaced
Hopefully this answers your question
Thank:)
Esta resposta foi útil?
Pontuação 1
1 comentário:
yes, they sell them at newegg and eBay and probably amazon. don't even try to transplant from another bud. not worth it
por
Here's an example link to an Aliexpress ... bot sure if it's allowed to post that link. But you can find them in any sizes and it works.
https://de.aliexpress.com/item/100500414...
Pontuação 1
Adicionar a sua resposta
Mike K será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 1,140
