Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Perguntas Visualizar todos
Ipad 2 Restore Loop
iPad 2 in restore loop.
Won’t restore in either DFU or Restore mode
Firmware loads until “Updating Baseband” then restore is stuck.
3U tool log shows the restoration stalling at “Updating baseband\n”.
Re-setting iPad returns iPad into restore loop
SHSH shows iPad2,2_9.3.5_13G36_Restore.ipsw is correct
iPad has battery works
Constructive thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
iTunes error #1 and reflowing
Appears to be hardware fault in either degrading flash or baseband chip according to the article above.
With an Apple Ipad 2 16gb GSM worth about $30 - $40 it doesn’t make sense to aim the “parts cannon” at it. Regards
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Skipwire será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 401
