Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
426 Perguntas Visualizar todos
My frigidaire top load washing machine won't continue any cycle.
The lid locks and the water will start to fill but only for a couple of seconds then stops. The same with draining. It will start to spin but only for a few seconds. I can hear clicking sounds from the motor control unit but then it stops. I've replaced the lid lock assembly. Also, when I begin the cycle, the washing machine will not spin to sense the cycle.
Update (02/19/2020)
Frigidaire Affinity FAHE1011MWO
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Hi @mhollings44 ,
Don’t know the answer, but hopefully this link to a Frigidaire washer tech data sheet is relevant to your model.
Try entering the diagnostic mode and check if there are any “LED error codes” that show up, that may point you in the right direction as to what the problem is.
Looking at the washer’s wiring diagram (scroll down the left side of the page and click on “wiring diagram”), once the lid is closed and locked most everything is controlled by the control board, with input from a some sensors, i.e. water level sensor, motor speed sensor and the lid lock switch, which you have replaced.
Of course the board could also be monitoring the motor, drain pump and heater as well to make sure that they’re all OK.
Update (02/20/2020)
Hi @mhollings44
Getting conflicting information regarding a code 53 and none is for your model.
The service manual for a Frigidaire FAHE4044MW0 washer, (different model I know but perhaps they kept the same operating protocols) show that a 53 error code is also low voltage at the Control board as mentioned by you.
As does an answer to a question regarding a Frigidaire front loader found in this link (scroll down the page to find Brad’s question)
The difference is that the first one says to refer to test #1 - sub part 3 which says check the incoming water pressure even though it says low voltage?? as the error code. But as all the 5x error codes seem to be motor related I’m hoping that this may be a mistake and it is a problem with the motor or the wiring to the motor
Test #7 for error code 52 seems to match up a lot better and also is in the same area as the answer to “Brad” above.
Also in the wiring diagram for your model there is a part shown as a “tach generator” (maybe a centrifugal switch as mentioned in Brad’s answer above). This is most probably mounted internally to the motorand is usually hard to get at. That is why they say replace the motor, but at least the wiring diagram shows the terminals to which it is connected and you can measure it for continuity.
If you have a DMM, then I suggest that you disconnect the power from the washer and check the wiring between the control board and the motor control board, maybe the tests as shown for test #7 will help but then maybe not.
What will help is that you do have the wiring diagram for your model so at least you know where the wires connect to.
Sorry that I can’t be of more help and hopefully I haven’t confused you with all this.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you for the response. I actually did this already and that's where I found that it will begin each part of the cycle but stops after a couple of seconds. The final diagnostic that gave the error code was 5 beeps, pause, 3 beeps. I cannot find this error code in any manual or info. This specific washing machine is discontinued. A service tech from JUST ANSWER told me that this error code means low voltage is being received. But he couldn't tell me for sure which part is causing the issue. I'm thinking either the lid lock assembly is bad or the motor control board needs replaced. I'd like to know what else could be the issue so I don't waste time and money. Also, it's VERY inconvenient not having a washing machine. I've called so many places but everyone wants to send a service tech.
por
Thank you for the response. I actually did this already and that's where I found that it will begin each part of the cycle but stops after a couple of seconds. The final diagnostic that gave the error code was 5 beeps, pause, 3 beeps. I cannot find this error code in any manual or info. A service tech from JUST ANSWER told me that this error code means low voltage is being received. But he couldn't tell me for sure which part is causing the issue. I'm thinking either the lid lock assembly is bad or the motor control board needs replaced. I've called so many places but everyone wants to send a service tech. When you mention most everything is controlled by the control board, are you referring to the main control board where the dials are or the motor control board in the front bottom right? That's where the clicking noise is coming from. I truly appreciate your help and information. I like to learn what I can and to fix these types of things, when I can.
por
Adicionar a sua resposta
Melissa Hollings será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 49
Duração total: 2,320
