upgrade hard drive possible?
I have a 30gb iPod and I was wondering if I can swap on an 80gb rear casing so that I can use a larger hard drive and the battery of the 80gb model.
Esta é uma boa pergunta?
Basically you need this stuff:
*60/80 gb rear panel
*60/80 gb headphone jack (it's about 1/4" longer
to reach around the thick hard drive)
*60/80 gb battery (longer to reach around HD)
*60/80 gb rubber bumpers (taller to protect logic board in thicker casing
check this thread for further reference.
Esta resposta foi útil?
Or try actually modding your ipod! check out https://www.amazon.ca/Micro-SATA-Cables-...
Yes... you could theoreticially, just remember the iPod may not function as well with the hard drive that it was not designed to carry. This is all I know on this topic so far, so if I were you, I would do a lot of research.
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 25
Ao todo: 1,402
