Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Home button not working
so my iPhone 7 had a cracked screen so I bought an ICloud locked 7 with a good screen to fix mine with, both phones home buttons functioned perfectly fine before the repair, I took the home button original to my iPhone and put it into the replacement screen, and the home function nor the Touch ID is working, I have completely taken apart the home button assembly and put it back together, I have even tried both home buttons and they don’t work, I have also carefully inspected the cables but none have any visible damage, I don’t know what else to do so I’m asking this community
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Let’s call your original phone “Phone A” and the for-parts model “Phone B”.
You say you moved Home Button A onto Display B, and Home Button A didn’t work.
If you put Home Button A back on to Display A, does it work on Phone A? If so, then either Display B is bad or Home Button A wasn’t seated properly on Display B. If not, then Home Button A was damaged during your repair attempt. The Touch ID circuitry is RIDICULOUSLY delicate and very easily damaged.
Esta resposta foi útil?
Pontuação 0
2 comentários:
The a button doesn’t work on the a screen, I think I might have damaged it
por
Unfortunately that would be my conclusion as well.
por
Have you afther you switch the screen and home-button connected the iphone with itunes and restore it? Sometimes this will help.
Pontuação 0
1 comentário:
No I haven’t tried that
por
Adicionar a sua resposta
Vipaha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 117
